[GRASS5] EPSG update to GRASS?
Stephan Holl
holl at gdf-hannover.de
Tue May 2 02:25:01 EDT 2006
Hello Markus,
On Thu, 27 Apr 2006 17:35:27 +0200 Markus Neteler <neteler at itc.it>
wrote:
> On Wed, Apr 26, 2006 at 09:56:32AM +0200, Markus Neteler wrote:
> > Hi,
> > please take the time to look at
> > http://bugzilla.remotesensing.org/show_bug.cgi?id=510
> > Frank updated EPSG files in PROJ and GDAL in CVS. I
> > assume that we should do the same to maintain synchronization.
> > If there are no objections, I'll update the two files
> > as indicated in above bug report.
> OK, I didn't see objections.
> So I have updated
> lib/proj/
> gcs.csv
> pcs.csv
> stateplane.csv
> in CVS using the recently updated files from GDAL (gdal/data/)
> which were also updated in PROJ4 (proj/nad/).
> Since new GDAL and PROJ releases are expected very soon, there
> shouldn't be any packaging issues.
for backward-compatibility could you tag (or somewhere promote the
cvs-commit-date of this update in CVS) so that we
know where to stop updating at least the proj-files to not run in
trouble when still using proj 4.4.9 and gdal 1.3.1?
Thanks
Stephan
