[GRASS5] NVIZ image dump broken?
Bob Covill
bcovill at tekmap.ns.ca
Wed May 3 08:00:52 EDT 2006
Markus,
I took a look at the thread below and it appears that the image is being
read incorrectly on 64 bit machines. The image buffer is created from
gsd_getimage in gsd_prim.c in ogsf. Unfortunately, I am not an expert on
64 bit machines, but I would guess that that either the malloc is wrong
or glReadPixels is wrong. Is an "unsigned long" a different size on 64
bit architecture? It appears that the dimension of the image is correct,
but the image buffer is wrong.
On a separate issue, I have found that with the recent NVIZ I get a
segfault if I try to load a saved state or save a state if I have a
vector/site file loaded. I assume this is due to the recent changes to
the Sites panel, but I have not had time to investigate. If you can
confirm, it should be added to the bugtracker.
Bob
On Wed, 2006-05-03 at 12:18 +0200, Markus Neteler wrote:
> On Wed, May 03, 2006 at 10:14:09PM +1200, Hamish wrote:
> > > > > the NVIZ image dump to TIFF no longer works for me.
> > > > > The result image is replicated inside the output
> > > > > file and basically useless.
> > > > I seem to remember this same problem was reported to the mailing list
> > > > just a few days/week ago. You are using 64bit, correct? I've got a
> > > > feeling that previous report was 64bit too.
> > > Right. I am using 64bit.
> > ht/dig is back online; gmane is still down-
> > here's the thread:
> > http://grass.itc.it/pipermail/grassuser/2006-April/033819.html
> This is exactly my problem!
> Where should I look for that?
> Markus
