[GRASS5] v.net.path
Robin Chauhan
robin.chauhan at gmail.com
Wed May 3 16:14:02 EDT 2006
On 5/3/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> On 5/3/06, Robin Chauhan <robin.chauhan at gmail.com> wrote:
> > Could anyone tell me if there have been any plans or developments for
> > v.net.path lately?
> > I have read this old thread on v.net.* implementation using dglib vs dgtable:
> > http://grass.itc.it/pipermail/grass5/2003-September/008673.html
> > ...which suggests dglib is abandoned and maybe should be replaced by
> > dgtable. But the URL for dgtable no longer works and Google gives
> > nothing on it.
> > I would also like to know which algo is used for shortest path in
> > dgtable... In my understanding dijkstra's as used by dglib is terribly
> > inefficient for the shortest path problem, I think A* would be far
> > better here.
> dglib is not slow, the only problem is to calculate matrices of costs
> for more points becaus dglib cache can fail it is disabled in v.net.* modules.
Many thanks for your reply, Radim.
Perhaps I should first focus on dglib cache and not the algorithm
used. I have also seen your email:
http://grass.itc.it/pipermail/grassuser/2003-November/010745.html
Do you know how I can enable the cache to try it? I tried just
uncommenting this line in Vect_net_build_graph ( in
lib/vector/Vlib/net.c ) :
dglInitializeSPCache( gr, &(Map->spCache) );
...but that didnt change my run times significantly.
Do you know more about the bug? I have seen the small note in
lib/vector/dglib/BUGS about it. But I cannot tell, is it just an
implementation detail bug, or a deeper theoretical problem.
-Robin
> Radim
> > -Robin Chauhan
