[GRASS5] v.digit still segfaults
Michael Barton michael.barton at asu.edu
Wed May 3 18:01:32 EDT 2006
Jachim,
Thanks for the details. That may help someone, but doesn't help me. I just
need to know if v.digit is breaking only when opened in gis.m, whether it
doesn't work when run from the v.digit module gui, and/or whether it doesn't
work when run completely from the command line.
If it's the last, it is a problem in the C module that still needs to be
fixed; if the first, it's a GIS Manager problem; if the second, its a
problem with the module GUI.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Jachym Cepicky <jachym.cepicky at centrum.cz>
> Date: Wed, 3 May 2006 22:10:11 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Wolf Bergenheim <wolf+grass at bergenheim.net>, GRASS developers
> <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] v.digit still segfaults
> Hallo,
> confirm, v.digit segfaults:
> GRASS 6.1.cvs:~ > v.digit -n pokus2
> New empty map created.
> Neoprávněný přístup do paměti (SIGSEGV)
> GRASS 6.1.cvs:~ >
> (gdb) run
> Starting program: /usr/local/grass-6.1.cvs/bin/v.digit -n pokus3
> [Thread debugging using libthread_db enabled]
> [New Thread -1240200992 (LWP 6824)]
> warning: Lowest section in /usr/lib/libicudata.so.34 is .hash at
> 00000094
> [New Thread -1240421456 (LWP 6828)]
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1240200992 (LWP 6824)]
> 0xb776a203 in strlen () from /lib/tls/libc.so.6
> (gdb)
> GRASS 6.1.cvs:~ > v.digit -n pokus4
> D1/5: Map opened
> D2/5: cat_init()
> D2/5: symb_line_init()
> D2/5: symb_node_init()
> D5/5: driver_open()
> D5/5:  -> opened
> D2/5: top = 0 bot = 480, left = 0 right = 640
> D2/5: n = 0.000000 s = 480.000000, w = 0.000000 e = 639.000000
> D2/5: n = 4927970.730460 s = 4915893.960560, w = 593020.769477 e =
> 609097.969406
> D2/5: Scale = 25.159937
> D5/5: driver_close()
> D5/5:  -> closed
> D5/5: driver_open()
> D5/5:  -> opened
> 609097.969406
> D2/5: display_bg()
> D5/5:  -> closed
> D5/5: driver_open()
> D5/5:  -> opened
> 609097.969406
> D2/5: display_map()
> D2/5: set color to symb 2: 255 255 0
> D2/5: set color to symb 13: 0 153 0
> D2/5: set color to symb 12: 255 0 0
> D5/5:  -> closed
> Segmentation fault
> GRASS 6.1.cvs:~ >
> I hope, this helps.
> Jachym
> On Wed, May 03, 2006 at 12:59:23PM -0700, Michael Barton wrote:
>> How did you run v.digit? From the GIS Manager, from the command line, both?
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
>>> Date: Wed, 3 May 2006 19:07:02 +0300 (EEST)
>>> To: GRASS developers <grass5 at grass.itc.it>
>>> Subject: [GRASS5] v.digit still segfaults
>>> Hi,
>>> I just did a fresh cvs checkout and rebuilt grass from scratch. v.digit
>>> still segfaults :(
>>> --Wolf
>>> <:3 )---- Wolf Bergenheim ----( 8:>
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
> e-mail: cepicky at gdf-hannover.de
> URL:    http://gdf-hannover.de
> Tel.:   +49 511-39088507
