[GRASS-dev] Re: [GRASS5] GEM in CVS
Sören Gebbert
soerengebbert at gmx.de
Thu May 4 08:44:03 EDT 2006
i just tried to install a GRASS extension via GEM.
But after the semi successful installation, my gis.m manager wont start anymore. :(
This is what i have done:
I compiled GEM as it is written in the docu, then i installed the RasterTools Extension with:
gem -v --install=/home/soeren/src/RasterTools.tar.gz --grass=/usr/local/grass-6.1.cvs
This warning occurs while the installation:
WARNING: Unknown format of index.html. Unable to register HTML man pages.
Then i startet grass61 and the gis.m manager stoped with this error:
Mapset <testmapset> in Location <TestLocation>
GRASS 6.1.cvs > Error in startup script: unmatched open brace in list
while executing
"llength $menu"
(procedure "MainFrame::create" line 62)
invoked from within
"MainFrame::create .mainframe -menu \n\ \"&File\"\ all\ file\ 1\ \{\n\t\ \{casca d\ \"Import\"\ \{\}\ \"\"\ 1\ \{\t\t\t\n\ \t\t\{cascad\ \"Raster\ map\"..."
("eval" body line 1)
invoked from within
"eval MainFrame::create $path $args"
(procedure "MainFrame" line 1)
invoked from within
"MainFrame .mainframe -menu $descmenu -textvariable Gm::status -progressvar Gm::prgindic "
(procedure "Gm::create" line 29)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 522)
The error is an unopen brace ... well .... but i have absolutely no clue of tcl and where to look
for this???
Can somebody please help me to get the gis.m back to work, without removing and installing grass again?
Many Thanks
Soeren
On Thursday 04 May 2006 09:10, Benjamin Ducke wrote:
> Thanks to Markus' help,
> the code for the GRASS Extensions Manager (GEM) is now in the CVS.
> Seeing that gis.m has made quite some progress lately and that
> it will likely become the default GUI for the next stable GRASS,
> this means we will be able to offer users a simple and seamless
> way to download and add extensions to a running GRASS installation.
> Perhaps this would be a good point to think which modules
> could in the future be developed outside the GRASS base and put into
> extensions.
> In the next weeks I will hopefully find some time to update all
> the extensions on my webpage so you can try the integration
> of extensions with gis.m
> Best,
> Benjamin
