[GRASS-dev] Re: grass.itc.it server migration to new machine
Markus Neteler neteler at itc.it
Thu May 4 12:51:07 EDT 2006
Hi again,
the new server is up and running now.
Please use
 grass-dev AT grass.itc.it
for future postings. The archives are at:
 http://grass.itc.it/pipermail/grass-dev/
For backward compatibility I have added an
alias for the old grass5 at grass.itc.it address.
I have also a link for 'grass5' archives so that
the existing few zillion references should still work.
All users with their settings should be migrated.
Special kudos to our admin Roberto Flor to work
around a nice Mailman migration bug!
Please report remaining problems.
Cheers
 Markus
PS: The earthquake map is significantly faster now :-)
    The Mapserver-GRASS demo application I'll install
    next week.
On Tue, May 02, 2006 at 11:06:02PM +0200, Markus Neteler wrote:
> Hi 'grass5' community,
> I forgot to mention that this is the chance to rename
> the mailing list to grass-dev.
> I think that I'll rename it and add an alias 'grass5'
> which points to grass-dev at grass.itc.it . The current
> name isn't really appropriate any more.
> Also the subject prefix I would update then.
> Any objections?
>  Markus
> On Tue, May 02, 2006 at 05:41:09PM +0200, Markus Neteler wrote:
> > Dear GRASS community,
> > this week we want to migrate 'grass.itc.it' to a new
> > machine. It is likely that the server is down for
> > 1 hour (maybe less, maybe more). The basic problem
> > is the migration of all mailing lists which requires
> > to stop the email server for the time of migration.
> > ITC-irst continues to support the GRASS project.
> > The good old server is up for 448 days now; we hope
> > that the new server behaves as well as the old one.
> > Additional change: Once the new machine is up (same
> > name, same IP), I want to migrate the GRASS User list
> > (kindly hosted at Baylor University) to our server to
> > get control over it. Currently we cannot help with
> > subsciption issues etc. The plan is to fully enable
> > the already existing GRASS User list which runs in
> > background for some years now (to maintain the list
> > archive - at Baylor no archive are provided). I'll
> > transfer all subscribers to the IRST based user list,
> > you will then receive an announcement with password.
> > Mails to the old Baylor address should still arrive
> > as our list here is subscribed as user there. Nothing
> > should get lost.
> > We try to miminize the outage time and we will announce
> > once the new server is up & running.
> > Best regards
> >  Markus
> > Markus Neteler     <neteler itc it>       http://mpa.itc.it
> > ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18        -       38050 Povo (Trento), Italy
