[GRASS-dev] Re: gis.m zoom functions, etc
Michael Barton michael.barton at asu.edu
Thu May 4 10:51:47 EDT 2006
We're not out of space yet, but this is a good idea. I'm already using this
for saving. It's called a menu button in TclTk. It might be a good idea for
some zooming (zoom to file, zoom to saved region, zoom to default, etc.). I
think it is good to keep commonly used buttons visible at the top level
however (zoom in, zoom out, maybe zoom back).
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Trevor Wiens <twiens at interbaun.com>
> Date: Thu, 4 May 2006 05:44:09 -0600
> To: Michael Barton <michael.barton at asu.edu>, Cedric Shock
> <cedricgrass at shockfamily.net>, GRASS5 <grass5 at grass.itc.it>
> Subject: gis.m zoom functions, etc
> Cedric and Michael,
> I woke up early thinking about this and I have a suggestion that might
> make this a little cleaner and easier to use.
> If we can have drop down buttons as in QGIS it is much easier. By this
> I mean buttons that can have a built in list of buttons which is
> accessed by clicking and holding to open a drop down of buttons. In
> this way similar functions can be grouped. It isn't necessary but it
> would help to keep the number of buttons across the top from becoming
> too large.
> A modified tool bar button would then appear from left to right as:
> Dropdown list of: Redraw changes, Redraw all
> NVIZ
> Erase
> Pointer
> Zoom In
> Zoom Out
> Pan
> Info / identify
> Measure
> Zoom to last
> Dropdown list of: Zoom to saved region, Zoom to vector, Zoom to
> raster, Zoom to system region, Zoom to default
> Save
> Print
> To summarize I'm suggesting two things.
> First adding functionality by allowing a forced redraw of everything
> without changing the zoom. For me this is useful as I often try things
> interactively before adding them to a script which involves the
> creation, display, deletion, and recreation, redisplay, ... Having the
> ability to redraw all, even though the system doens't register any
> changes would be nice.
> Second, adding three new buttons to zoom to system wide settings, zoom
> to a vector and zoom to a raster.
> Part Two
> Separate from the zoom question I have some suggestions about the
> display tool bar and tools. Sorry I'm sure you've heard lots of comment
> on this but if you don't like it, just ignore it. Thanks
> First, for zooming and panning I would really like it if I could have a
> single tool which would default to zoom in, but right clicking would
> zoom out and the middle button would allow for panning. For people
> using Mac's and their single button mouse, control keys could be
> used to emulate this behaviour or one might want to provide both
> control key and mouse button options, because when the control key was
> pressed, the cursor could be changed to provide a functional cue to the
> user. This means when navigating would be a whole lot quicker. I
> realize for newbies, perhaps the extra buttons might be needed, but if
> tool drop downs available we could group the three into one bar with
> the default to the generic tool.
> Second, and related to this is the question of the pointer. Since
> it doesn't actually do anything why have it. Perhaps defaulting to a
> zoom/pan tool would be more natural.
> The net effect of these changes would be increased operational speed
> and ease of use and removal of 3 spots on the tool bar.
> The modified tool bar would then be:
> NVIZ
> Erase
> Measure
> Info / identify
> Dropdown list of: Zoom/Pan, Zoom In, Zoom Out, Pan
> Zoom to last
> Save
> Print
> Thanks for your consideration of these ideas
> T
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
