[GRASS-dev] Re: [GRASS5] r.mapcalc bug/64bit?
Glynn Clements
glynn at gclements.plus.com
Thu May 4 21:12:03 EDT 2006
Hamish wrote:
> > r.info -r duration
> > min=-2147483648
> > max=-2147483648
> r.info modified in CVS to report nan,nan for a CELL map of all NULLs.
May I suggest "null" rather than "nan"?
"null" is the term normally used in GRASS documentation, while the use
of NaN for FP nulls is an implementation detail.
