[GRASS-dev] OGSF Headers
Glynn Clements
glynn at gclements.plus.com
Fri May 5 01:09:00 EDT 2006
Brad Douglas wrote:
> Is there any particular reason that headers from the OGSF library reside
> with the source and then are copied to "include/" after compilation?
AFAICT, no.
> Shouldn't they be moved to "include/" and left there like has happened
> with other libraries?
Probably.
> I don't see any automatic header file generation that would preclude
> from doing so.
local_proto.h gets renamed to ogsf_proto.h during the installation,
and gstypes.h is modified accordingly. But that's trivial to change.
