[GRASS-dev] Re: New qgis-grass win32 build
Radim Blazek
radim.blazek at gmail.com
Fri May 5 08:01:10 EDT 2006
On 5/5/06, Sören Gebbert <soerengebbert at gmx.de> wrote:
> But the module v.buffer is kind of strange while generating output with many
> lines and
> buffers greater then ~50m on different machines (linux).
> I checkded this some time ago and figured out, that the output is equal, but
> the order of the produced lines is different between the machines! I have no
> clue why.... .
I was already thinking about v.diff, in any case it would be interesting
to find why the order can differ.
> > What does it mean dependencies not fulfilled?
> This is a new feature. The test suite is trying to figure out what
> dependences the grass installation has.
> e.g.: if gdal, ogr, postgresql, mysql and stuff is linked against grass
> Within the test scripts you can define this dependences.
> The r.in.gdal and r.out.gdal modules depend on gdal,
> so i made the entry NEED_GDAL="yes" in the test scripts.
But it obviously fails because r.in/out.gdal should work.
Cannot you simply try to run r.in.gdal --help?
> Can i run those tests within Windows 98? So i can use vmware
> and dont have to boot Windows XP. I have only one XP license.
I think that XP is better, I dont believe many people are using 9x.
Radim
