[GRASS-dev] Re: [GRASS5] Improvements to gis.m map canvas
Glynn Clements
glynn at gclements.plus.com
Fri May 5 13:09:55 EDT 2006
Hamish wrote:
> > > Because it is likely that drawing a box by hand with a mouse will
> > > not exactly come up with the exact same x:y ratio of the current
> > > canvas.
> Hi, slightly off-topic but,
> Is it possible to use an XOR coloring to draw the zoom box as a inverse
> of the background instead of always yellow? The box disappears on yellow
> parts of the map..
No; the Tk canvas doesn't support XOR plotting.
One option is to use two identical boxes in different colours, with
the top box having a dash pattern while the bottom box is solid.
