[GRASS-dev] Tcl and shell script option translation
Cedric Shock
cedricgrass at shockfamily.net
Sat May 6 14:10:34 EDT 2006
I've made some improvements to the localization system.
Tcl files get their G_msg stripped by xgettext for translation, translations
are installed where G_msg finds them. This is pretty straightforward.
Translation of script options:
g.parser has a new -t switch (before filename, can't interfere with other
parser behaviours) that outputs the translatable strings in the options of a
script. g.parser also gettext()s the same strings when running normally.
Script.make runs g.parser to get the strings, writes them to
locale/scriptstrings/_______.c fake c files. The regular rules for searching
c strings pick up here and find these all as grass module strings. (These
are cleaned out on "make clean".
There is one gotchas to this all. "make" must be run by the translator (or
someone else to prepare templates for translation) before translation instead
of just "make pre".
It might also be wise to make a blitz of internationalizing before asking or
suggesting that translators translate the newly exposed strings. It's much
more rewarding, working on something like translation, to do a little more
work and have a fairly complete looking result (not having gui windows that
are half english, etc.). Such a blitz could culminate with committing all
the .po files with the new blank strings to cvs to lessen the load on
translators.
--Cedric
