[GRASS-dev] Re: [GRASS5] [bug #4331] (grass) delete if file exist -
flag
Cedric Shock
cedricgrass at shockfamily.net
Sat May 6 19:47:10 EDT 2006
> This (documentation) should be implemented into the parser.
> A way could be to check if a module used
> cd ~/grass61/lib/gis > grep OUTPUT parser.c
> case G_OPT_R_OUTPUT:
> case G_OPT_V_OUTPUT:
A simpler and more accurate way would be to check, in parser.c, if any of the
options use a gisprompt of new,*. But this option really only works for c
modules. The check_overwrite routine in parser.c will probably reject the map
name again in modules called from a script that was passed the --o flag.
Scripts probably won't notice this nor pass it to modules that the script
calls. I'm not sure if there's even a method for passing this back to the
script from g.parser. There is a grass environment variable OVERWRITE that
parser.c checks as well as the --o flag, but I don't think it's set for
scripts run by g.parser. Should it be for consistency (seems dangerous)?
Perhaps it would be possible for parser.c to tell the difference between a
call from g.parser and a call from other modules to produce this help output
only for c grass modules that use new,*.
Anyway, I didn't find a simple change that won't produce false positives on
scripts.
--Cedric
