[GRASS-dev] db.connect exit codes
Mon May 8 02:17:39 EDT 2006
currently if no DB/driver is defined (new mapset), "db.connect -p" returns
with an error code of 0.
G61> db.connect -p
driver:(null)
database:(null)
schema:(null)
group:(null)
G61> echo $?
0
This makes it hard to test in a script... (v.db.addtable fails)
I assume the (null) comes from printf("%s",..);
Is there anything wrong with setting it to something >0 and ideas on how
to do that?
Hamish
