[GRASS-dev] [bug #4427] (grass) Error in startup script
Request Tracker
grass-bugs at intevation.de
Mon May 8 04:59:45 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4427
Subject: Error in startup script
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: /grass6.1.cvs-x86_64-unknown-linux-gnu-0
This is FC-5, AMD-64, nvidia, 2GB RAM, 3x80 GB HDD
Links:
lrwxrwxrwx 1 root root 16 Apr 17 09:25 /usr/lib/libgdal.so -> libgdal.so.1.9.0
[mockus at localhost grass]$ ls -l /usr/lib/libtk.so.0
lrwxrwxrwx 1 root root 25 May 8 11:45 /usr/lib/libtk.so.0 -> /usr/local/lib/libtk.so.0
[mockus at localhost grass]$ ls -l /usr/lib/libtcl.so.0
lrwxrwxrwx 1 root root 26 May 8 11:45 /usr/lib/libtcl.so.0 -> /usr/local/lib/libtcl.so.0
[mockus at localhost grass]$ ls -l /usr/lib/libdfftw.so.2
lrwxrwxrwx 1 root root 28 May 8 11:46 /usr/lib/libdfftw.so.2 -> /usr/local/lib/libdfftw.so.2
Errors:
Welcome to GRASS 6.1.cvs (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
Start the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.1.cvs (d2142):/home/md/grass > gis.m &
[1] 4550
GRASS 6.1.cvs (d2142):/home/md/grass > Error in startup script: g.region: error while loading s$libraries: libgdal.so.1: wrong ELF class: ELFCLASS32
while executing
"close $input"
(procedure "MapCanvas::zoom_gregion" line 7)
invoked from within
"MapCanvas::zoom_gregion $mon"
(procedure "MapCanvas::create" line 39)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 70)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass6.1.cvs-x86_64-unknown-linux-gnu-06_05_2006/etc/gm/gm.tcl" line 521)
-------------------------------------------- Managed by Request Tracker
