[GRASS-dev] [bug #4430] (grass) v.out.ascii: please allow 'output=' even without '-o' set
Request Tracker grass-bugs at intevation.de
Mon May 8 07:23:06 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4430
Subject: v.out.ascii: please allow 'output=' even without '-o' set
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006-05-08
v.out.ascii will always output to stdout if '-o' (output in old format version) is not used. If trying to use 'output=filename' without '-o' it is taken as an error: "Cannot open file [filename]".
This makes it problematic to use v.out.ascii from GUI. I think it should be allowed to use 'output=filename' also without '-o' set.
Maciek
-------------------------------------------- Managed by Request Tracker
