[GRASS-dev] [bug #4426] (grass) Almost entire GRASS database
deleted. Suspect grass startup.
Cedric Shock via RT
grass-bugs at intevation.de
Mon May 8 12:22:28 EDT 2006
Please help by suggesting what program could have done this short list of
symptoms:
All grass database files (vectors, rasters, regions, etc.) and their
directories completely removed.
Projection and other support files except for MYNAME removed. MYNAME still has
the correct name for the location, so the whole folder wasn't deleted.
WIND and DEFAULT_WIND either removed and rewritten with proj and zone lines or
all the defaults of 0 and 1 were written to the remaining files.
-------------------------------------------- Managed by Request Tracker
