[GRASS-dev] [bug #4428] (grass) gis.m/r.what incompatible: quering rasters outside current region doesn't work
Mon May 8 18:01:27 EDT 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4428
> Subject: gis.m/r.what incompatible: quering rasters outside current region doesn't work
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2006-05-08
> Quering rasters in gis.m doesn't work properly because r.what depends on current region settings, which gis.m ignores. False nulls are returned as an efect.
> Can r.what be fixed to query raster outside the current region?
Wrong solution. gis.m needs to set WIND_OVERRIDE correctly before
calling r.what.
