[GRASS-dev] [bug #4428] (grass) gis.m/r.what incompatible:
quering rasters outside current region doesn't work
Glynn Clements
glynn at gclements.plus.com
Tue May 9 04:56:56 EDT 2006
Hamish wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=4428
> > > Subject: gis.m/r.what incompatible: quering rasters outside current
> > > region doesn't work
> > > GRASS Version: 2006-05-08
> > > Quering rasters in gis.m doesn't work properly because r.what
> > > depends on current region settings, which gis.m ignores. False nulls
> > > are returned as an efect.
> > > Can r.what be fixed to query raster outside the current region?
> > Wrong solution. gis.m needs to set WIND_OVERRIDE correctly before
> > calling r.what.
> WIND_OVERRIDE and GRASS_REGION are not documented in the enviroment
> variables help page,
> http://grass.ibiblio.org/grass61/manuals/html61_user/variables.html
> Can someone describe how to use them?
First and foremost, the user should not set WIND_OVERRIDE in a GRASS
session. It's meant to be set locally for specific commands. It's
debatable whether it belongs in the users' manual.
As for what it does:
int G_get_window (struct Cell_head *window )
wind = getenv("WIND_OVERRIDE");
if (wind)
err = G__get_window (&dbwindow,"windows",wind,G_mapset());
else
err = G__get_window (&dbwindow,"","WIND",G_mapset());
It causes programs to use the specified named region (created with
e.g. "g.region save=...") to be used as the current region, instead of
the region from the WIND file.
This allows programs such as gis.m to run external commands on an
alternate region without having to modify the WIND file then change it
back afterwards.
