[GRASS-dev] [bug #4368] (grass) g.parser: pass through --o
Cedric Shock via RT
grass-bugs at intevation.de
Tue May 9 15:36:01 EDT 2006
parser.c now sets the OVERWRITE environment variable, but doesn't export it.
Scripts run by g.parser now have it set so that modules they run will be run
as if --o was included. It can be used here to skip the overwrite check that's
implemented in r.blend to check for .r .g and .b extensions to the map name.
-------------------------------------------- Managed by Request Tracker
