[GRASS-dev] [bug #4368] (grass) g.parser: pass through --o
Radim Blazek
radim.blazek at gmail.com
Wed May 10 04:32:39 EDT 2006
On 5/10/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Actually, the "fixes" have also been rather ad-hoc. It might be better
> to do away with WIND and store the name of a saved region in $GISRC
> instead, remove MONITOR_OVERRIDE and WIND_OVERRIDE, and just create an
> alternate $GISRC file whenever you want to change any of those
> parameters.
Note that it is also possible to set region with GRASS_REGION
environment variable.
Radim
