[GRASS-dev] endian & generic library
Brad Douglas
rez at touchofmadness.com
Wed May 10 12:20:55 EDT 2006
On Wed, 2006-05-10 at 18:29 +1200, Hamish wrote:
> > > > Understood re: endian programming issues. Should it go into
> > > > SUBMITTING?
> > > SUBMITTING isn't supposed to be a tutorial on C programming (even if
> > > many contributors badly need one).
> FWIW, this is what the Linux Kernel's version looks like:
> http://lxr.linux.no/source/Documentation/CodingStyle
I believe GRASS should have a similar document that is a bit more
expansive and covering design decisions that affect coding style. I
think it would cut down on repeat questions.
I have no issues producing the first draft.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
