[GRASS-dev] Re: [GRASS5] [bug #4331] (grass) delete if file
exist - flag
Glynn Clements
glynn at gclements.plus.com
Wed May 10 19:10:07 EDT 2006
Hamish wrote:
> > G_parser now sets, but doesn't export, the OVERWRITE environment
> > variable.
> For consistency with other g.parser set vars shouldn't it be
> GIS_OVERWRITE? ($GIS_OPT_ $GIS_FLAG_)
It isn't quite the same thing; $GIS_{OPT,FLAG}_* are purely for
communication between g.parser and the script, while [GRASS_]OVERWRITE
is meant to be propagated down into the commands which the script
runs.
[The GIS_{OPT,FLAG}_* variables will also be propagated, but that's an
unintentional side-effect of using environment variables. With
[GRASS_]OVERWRITE, it's intentional.]
> Does the new fn check G__getenv() for OVERWRITE=1 and if found set the
> enviro var even if --o wasn't given? Redundant for the modules, but not
> for example the r.blend $.r $.g $.b check.
It should do now; see Cedric's follow-up.
