[GRASS-dev] [bug #4368] (grass) g.parser: pass through --o
Thu May 11 02:48:04 EDT 2006
> > Actually, the "fixes" have also been rather ad-hoc. It might be
> > better to do away with WIND and store the name of a saved region in
> > $GISRC instead, remove MONITOR_OVERRIDE and WIND_OVERRIDE, and just
> > create an alternate $GISRC file whenever you want to change any of
> > those parameters.
It is nice to have the WIND file and its contents out in the open and
easy to look at from the file sytstem vs. being buried somewhere in a
hidden file. It's the one file (besides the dir) you need to make a new
(+ clean) mapset. Alternate $GISRC files would get confusing rather
quickly, bring along unwanted settings from the previous version, etc;
especially if they are persistent on the disk/not cleaned up.
Hamish
