[GRASS-dev] [bug #4270] (grass) v.in.ascii field separator
Cedric Shock via RT
grass-bugs at intevation.de
Fri May 12 02:03:54 EDT 2006
Could you clarify a bit please: What do you mean by GUI? Did you run
v.in.ascii from the console without any options?
I tried importing a ; delimited file with v.ascii and it worked just fine for
me entering only ; in the "Field Seprator:" box in the GUI.
Thanks,
--Cedric
-------------------------------------------- Managed by Request Tracker
