[GRASS-dev] problem with graphical user interface
Serena Pallecchi
pallecch at cli.di.unipi.it
Fri May 12 06:25:28 EDT 2006
hi all.
i've just installed grass-6.1.cvs_src_snapshot_2006_05_10.
when i press the button "enter grass" the shell shows me this message:
GRASS 6.1.cvs (ciao):/home/serena > Error in startup script: unknown option
"-of
frelief"
while executing
"radiobutton $tb.pointer -image [image create photo -file
"$iconpath/gui-pointe
r.gif"] -command "MapCanvas::stoptool $mon" -variable maptools -value..."
(procedure "MapToolBar::create" line 40)
invoked from within
"MapToolBar::create $map_tb"
(procedure "MapCanvas::create" line 50)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 71)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 527)
and the graphical user interface doesn't run.
how can i solve this problem?
Serena
