[GRASS-dev] Large Polygon-datasets
Stephan Holl holl at gdf-hannover.de
Fri May 12 08:06:54 EDT 2006
Hello Radim,
On Tue, 9 May 2006 13:53:20 +0200 "Radim Blazek"
<radim.blazek at gmail.com> wrote:
> On 5/9/06, Hamish <hamish_nospam at yahoo.com> wrote:
> > > I have a very large dataset containing about 300.000 polygones
> > > which I would like to import into GRASS using v.in.ogr
> > > Is there a possibility to not build the topology during import,
> > > but afterwards. It runs nor about several hours now and does not
> > > provide more information than
> > > Importing 300000 map features...
> > > and nothing more. The maschine is very slow in response using the
> > > mouse.
> > > Does anybody have some experience in using this kind of datasets?
> > > Thanks for any suggestions how to import the data.
> > Yes, I have seen this and IIRC there was a Florida Coastline import
> > with the same problem.
> > In all cases the polygons were all unbroken polygons with only one
> > end node breaking a single boundary line.
> > At the time, Radim wrote:
> > > Now I have just one idea, because the areas are probably isolated,
> > > it could be that exist one BIG boundary around all the map
> > > (I thing that something like that exists in ArcInfo),
> > > in that case, when this boundary is processed, it selects
> > > lines which could intersect it by bounding box, in that case ALL
> > > lines, and to check intersection of ALL segments of that BIG line
> > > with ALL segments of ALL other lines can take a very long time.
> > I think this case is why he wrote v.split.
No this is not the case. When I apply the spatial=-switch of v.in.ogr
the module imports fine, because the area is small enough (about
100.000 polygones).
> It must go to v.in.ogr.
> v.in.ogr -c + anything != v.in.ogr
I do not understand what you mean by the above. Could you elaborate,
please?
Anyway, is there an elegant way to import large datasets even on
non-RAM-monster-maschines?
Thanks for you comments
	Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
