[GRASS-dev] [bug #4368] (grass) g.parser: pass through --o
Cedric Shock cedricgrass at shockfamily.net
Sat May 13 13:31:09 EDT 2006
Jachym,
The --o flag has been in grass for a long time. Things that start -- in grass
are options to the parser, things that start - are flags that are parsed by
the parser for the module. --o tells the parser not to check that to make
sure elements in "new" gisprompts don't exist.
The following are also parser options, all of these options must be the first
argument:
--help
show usage and exit. Also -help and help work for ease.
--interface-description
Print out xml description of command line interface and exit
--html-description
Print out html usage help for command to be integrated in manual pages.
--tcltk
Print out tcl/tk source code to be evaluated after sourcing gui.tcl to make a
user interface. This is for user interfaces like d.m and gis.m.
--ui
Force the gui user interface to run. This can be used by itself or in
combination with options and flags to preload those options and flags into
the ui. This could be changed so that it doesn't need to be the first
argument, since it doesn't preempt parsing.
--o and --overwrite
These don't need to be in the first argument. They override existing map check
for this command only.
Note that overwrite can also be set by g.gisenv so that it happens
automatically for all commands. Some users (at least me) prefer to not have
maps automatically overwritten, but for it to be easy to do for a single
command.
The only recent change was adding --o to the help. It was added to module help
because it is specifically useful for modules that employ a new gisprompt.
--Cedric
