Hamish wrote: > [*] using the same map name for both in= and out= with --o is bad, yes? Maybe Vect_check_input_output_name ( inopt->answer, outopt->answer, GV_FATAL_EXIT ); should catch this (maybe it does?)? See v.extract for example. Markus
