[GRASS-dev] ./configure error
Paolo Cavallini cavallini at faunalia.it
Mon May 15 12:30:31 EDT 2006
Following:
http://www.intevation.de/rt/webrt?serial_num=3918&display=History
I ran:
/usr/src/grass# autoconf
configure.in:366: warning: AC_CANONICAL_HOST invoked multiple times
autoconf/specific.m4:362: AC_CYGWIN is expanded from...
configure.in:366: the top level
./configure now stops at:
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)... ./configure: line 8097:
syntax error near unexpected token `('
./configure: line 8097: `    case `(uname -sr) 2>/dev/null` in'
running it with -x stops at:
+ echo 'LTLIBOBJS='\'''\'''
+ echo
+ test -n ''
+ test -s confdefs.h
+ cat
+ echo
+ sed '/^$/d' confdefs.h
+ sort
+ echo
+ test 0 '!=' 0
+ echo 'configure: exit 258'
+ rm -f core '*.core'
+ rm -rf 'conftest*' confdefs.h 'conf22817*'
+ exit 258
Dos this help understanding the problem?
At 16:11, lunedì 15 maggio 2006, Markus Neteler has probably written:
> Paolo Cavallini wrote:
> >While installing on a high-end machine [1], at ./configure I get:
> >checking system version (for dynamic loading)... ./configure: line 12467:
> >syntax error: unexpected end of file
> >The file seems ok. Any suggestion?
> You could change the first row of 'configure'
> from
> #! /bin/sh
> to
> #! /bin/sh -x
> then launch again and see more details.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
