[GRASS-dev] nviz does not start
    Stefan Paulick
    stefan.paulick at urbeli.com
    Tue May 16 00:30:43 EDT 2006
> FWIW, tcltk 8.4 hasn't changed in Debian since Feb 8th.
>  http://packages.qa.debian.org/t/tcl8.4.html
> Hamish
Tried to create a new location, but it failed while starting gis.m(?)
d.m does start; r.in.bin is working too. g.region fails from the gui,
called from CLI it works.
When displaying on x0, a huge error window with big letters is rising,
but I can't read it while it is extending the screen and it can't
neither be scrolled or propper moved. Can this error be trapped in a
smaller and scrollable window?
Has something related to gis.m changed the during the last 2-3 days?
Maybe the error only shines up after a distclean.
/Stefan
    while executing
"close $input"
    (procedure "MapCanvas::zoom_gregion" line 7)
    invoked from within
"MapCanvas::zoom_gregion $mon"
    (procedure "MapCanvas::create" line 39)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 71)
    invoked from within
"Gm::create"
    (procedure "main" line 29)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 527)
"main $argc $argv"
//here it stops...
r.in.bin input=/home/grassdata/ETOPO5.DAT output=map title=worldmap
bytes=2 north=90 south=-90 east=180 west=-180 rows=2160 cols=4320 -b
