[GRASS-dev] ./configure error
Markus Neteler neteler at itc.it
Tue May 16 04:27:30 EDT 2006
Markus Neteler wrote:
>Paolo Cavallini wrote:
>>Found it:
>>http://www.intevation.de/rt/webrt?serial_num=3918&display=History
>>just remove an excess apostrophe from:
>>           if test -r /etc/.relid -a "X`uname -n`" = "X`uname -s`" ; then
>>               system=MP-RAS-`awk '{print }' /etc/.relid'`
>>Please update the cvs.
>The CVS *is* updated (for some weeks now) (also GRASS 6.0-CVS).
>Apparently your local copy is outdated. If you read at bottom of
>you see that I fixed it and closed the report.
Sorry for being dense, I didn't understand that you work with GRASS 5.
I have fixed it now also in GRASS-5-CVS.
Markus
