[GRASS-dev] ./configure error
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue May 16 05:32:53 EDT 2006
On Tue, 16 May 2006, Markus Neteler wrote:
>>> http://www.intevation.de/rt/webrt?serial_num=3918&display=History
>>> just remove an excess apostrophe from:
>>>           if test -r /etc/.relid -a "X`uname -n`" = "X`uname -s`" ; then
>>>               system=MP-RAS-`awk '{print }' /etc/.relid'`
>>> Please update the cvs.
>> The CVS *is* updated (for some weeks now) (also GRASS 6.0-CVS).
>> Apparently your local copy is outdated. If you read at bottom of
>> you see that I fixed it and closed the report.
> Sorry for being dense, I didn't understand that you work with GRASS 5.
> I have fixed it now also in GRASS-5-CVS.
And now I have also updated 5.4 release branch!
Paul
