[GRASS-dev] povray and grass
Hamish
hamish_nospam at yahoo.com
Thu May 18 20:46:14 EDT 2006
> > > Those functions aren't the problem. The problem with v.extract is
> > > that it's calling them before it calls G_gisinit(), which is
> > > supposed to be called before any other GRASS function.
> > > [Apart from anything else, G_gisinit() sets the program name,
> > > which is used by G_fatal_error(), so anything which might cause
> > > G_fatal_error() to be called (i.e. almost everything) cannot
> > > safely be called before G_[no_]gisinit().]
> > > I have no idea whether or not this actually causes problems at
> > > present; I'm just pointing out that it's a bug regardless of
> > > whether or not you happen to "get away with it".
> > Added some comments to lib/gis/parser.c about this for more
> > visibility. (non-doxygenized header)
> > I notice g.region has fallen afoul of this rule in the last 2 weeks.
> I noticed that g.region didn't comply (use of llinfo() and
> G_{lat,lon}_format_string()) when I updated it to handle GRASS_REGION
> and WIND_OVERRIDE, but I didn't realise that this was recent.
The recent change was to call G__get_window() before G_parser() so that
the llinfo() fn doesn't depend on an uninitialised value.
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/g.region/cmd/main.c
solution is probably to abandon the llinfo() string, it's nice but not
critical.
Hamish
