[GRASS-dev] new profiling tool and other gis.m updates
Michael Barton
michael.barton at asu.edu
Sat May 20 15:55:29 EDT 2006
Thanks for the feedback Trevor. I'll try to track this down. I suspect it is
simply not trapping correctly errors where you have no profile line defined.
One thing I forgot to mention is that you can have multi-segment profiles.
That is, you aren't restricted to a straight line. Each segment is marked on
the profile by a vertical grey line.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Trevor Wiens <twiens at interbaun.com>
> Date: Sat, 20 May 2006 09:34:07 -0600
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass developers list <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] new profiling tool and other gis.m updates
> On Fri, 19 May 2006 14:02:47 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
>> I forgot to update the new pkgIndex.tcl file in the cvs. This sources
>> profile.tcl. I just did this.
> It is working now. However, when I erase I get an error sometimes, but
> not all the time.
> can't unset "linex1": no such variable
> while executing
> "unset linex1"
> (procedure "GmProfile::perase" line 23)
> invoked from within
> "GmProfile::perase .mapcan(1).mf.frame.mapcanvas"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .profile.mf.topf.tb0.bb.b3"
> (command bound to event)
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
