[GRASS-dev] Re: grass-dev Digest, Vol 1, Issue 2297
Glynn Clements
glynn at gclements.plus.com
Sun May 21 06:00:41 EDT 2006
Glynn Clements wrote:
> I've commited an update using Togl 1.7. This should make native Mac
> support one step closer. However, the README.stubs file from the Togl
> package says:
> It has been tested on Windows NT/2000 and Linux for several
> Tcl/Tk versions up to 8.4a3. I haven't been able to test the
> Mac port, it propably needs mending but I can't see why it
> shouldn't work in principle.
> I'll look at conditionalising the GLX-specific stuff in do_zoom.c
> next.
I've done that, and also changed the Makefile so that it only uses X
libraries if USE_X11 == 1.
The rest needs someone with a Mac to try building it using
--without-x. I suspect that it will probably need some additional
compiler/linker switches for the Mac's GUI libraries.
