[GRASS-dev] Re: Live Earthquake Map: GRASS/PHP
Markus Neteler
neteler at itc.it
Mon May 22 06:27:24 EDT 2006
On Wed, Apr 26, 2006 at 09:34:40AM +0200, Markus Neteler wrote:
> >>> http://grass.itc.it/spearfish/php_grass_earthquakes.php
> >>> Recent Earthquakes: map generated by GRASS on the fly with PHP
The new machine (grass.itc.it) offers PHP 5, so I had to
rewrite the code.
The PHP4 code example is at
http://grass.itc.it/spearfish/php_grass_earthquakes_PHP4.php
and no longer works on that machine, not sure why (I don't
know much about PHP).
The new PHP5 code example is at
and also fails!
The debug output is:
echo \$LD_LIBRARY_PATH >> grasserrors2.txt;
echo \$PATH >> grasserrors2.txt;
echo \$GISRC >> grasserrors2.txt;
which prints:
/lib:/usr/lib:/usr/local/grass-6.1.cvs/lib
/bin:/usr/bin:/usr/local/bin:/usr/local/grass-6.1.cvs/bin:/usr/local/grass-6.1.cvs/scripts
/grass0/neteler/www/spearfish/.grassrc6_ll
ERROR: LOCATION_NAME not set
I don't understand why 'lynx' works (to fetch the USGS bulletin),
also 'convert' to make JPG from PNG, but the GRASS commands fail
with 'LOCATION_NAME not set'.
ls -la /usr/local/grass-6.1.cvs/bin | wc -l
288
GRASS is there...
There is still a map shows in the PHP page as I didn't remove the
output from the last run on the old machine.
Any ideas?
Markus
