[GRASS-dev] new profiling tool and other gis.m updates
Trevor Wiens twiens at interbaun.com
Mon May 22 15:53:28 EDT 2006
On Mon, 22 May 2006 09:34:12 +0100
Glynn Clements <glynn at gclements.plus.com> wrote:
> The simplest approach would be to have a file which stores the event
> sequences in an array, then have any bind commands use that, e.g.:
> bindings.tcl:
> 	set bindings(mapcan_redraw) <KeyPress-c>
> 	set bindings(mapcan_zoom) <KeyPress-space>
> 	# allow user to override bindings
> 	source $env(HOME)/.gis.m/bindings.tcl
> Other Tcl files:
> 	source $gmpath/bindings.tcl
> 	global bindings
> 	bind .mapcan($mon) $bindings(mapcan_redraw) {...}
> 	bind .mapcan($mon) $bindings(mapcan_zoom) {...}
> This should be done for key and mouse events, but not "system" events
> such as Configure, Destroy, FocusIn, etc.
> Note that Tk allows some abbreviations. E.g. Key/KeyPress can be
> omitted if the keysym is given, so <KeyPress-Escape> can be
> abbreviated to <Escape>. Button/ButtonPress can be omitted if the
> button number is given, so <ButtonPress-1> can be abbreviated to <1>.
> For clarity, I would suggest avoiding the use of these abbreviations
> in the code, using the most explicit form instead.
Thanks Glynn,
I'll get working on that this week.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
