[GRASS-dev] GUI platforms
Tue May 23 01:25:23 EDT 2006
> Since (I think) g.parser is specific to TclTk, a new version would
> need to be written that is not--either in the GUI platform or in GRASS
> functions/libraries.
Probably it will be best to parse the existing XML --interface-description
either in real-time, at main compile time, or rebuild a module DB in CVS
whenever a new module is added. I expect it is much harder to "source" &
compile command files at run time with other toolkits than it is with
TclTk (??).
Hamish
