[GRASS-dev] GUI platforms
Michael Barton
michael.barton at asu.edu
Tue May 23 01:46:10 EDT 2006
True.
However, you need a way of communicating with the OS. And a repeated request
is to maintain a CLI for such communication. Hence, there needs to be a
terminal-like interface built into the the GUI where commands can be issued.
A further complicating factor is running GRASS under Windows. Even though
I'm not a big Windows fan, a LOT of people use this platform. It would be
great if GRASS could run in Window without the Cygwin emulator. There is a
version in development now that compiles under MinGW to create a
'Windows-native' GRASS. I assume that you can't issue Unix commands in that
environment. But you should be able to issue commands for Windows versions
of scripting languages like Python.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: David Finlayson <david.p.finlayson at gmail.com>
> Date: Mon, 22 May 2006 22:34:36 -0700
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Trevor Wiens <twiens at interbaun.com>, grass developers list
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] GUI platforms
>>> 2. Provide a CLI interface for GRASS program modules
>> Do we need to drop bash? If so a lot of existing modules and add on's
>> will go away or need to be ported for 6.3. Or do we envision providing
>> something like a language based shell (eg Python) as well as bash for
>> 6.3 to allow for transition and dropping shell programming for 6.4 or
>> 6.5 (I now way out in the future, but worth thinking about so we don't
>> make short term decisions that limit that vision).
> GRASS doesn't just depend on an X11 display; it depends on Unix. You
> can't remove the Unix part and still have GRASS. Unix permiates GRASS
> to the core. The GUI should make it easier to use GRASS and Unix not
> try to replace it.
