[GRASS-dev] [bug #4493] (grass) gis.m fails to start GUI
Request Tracker
grass-bugs at intevation.de
Tue May 23 15:33:48 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4493
Subject: gis.m fails to start GUI
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: GRASS 6.1.cvs (20060520)
Error description:
Typing "grass61" at the unix shell prompt opens the grass Startup window. Clicking on "Enter GRASS" yields
Welcome to GRASS 6.1.cvs (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: C Shell (/bin/csh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
Mapset <PERMANENT> in Location <spearfish60> GRASS 6.1.cvs > Error in startup script: unknown option "-offrelief"
while executing
"radiobutton $tb.pointer -image [image create photo -file "$iconpath/gui-pointer.gif"] -command "MapCanvas::stoptool $mon" -variable maptools -value..."
(procedure "MapToolBar::create" line 40)
invoked from within
"MapToolBar::create $map_tb"
(procedure "MapCanvas::create" line 50)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 71)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 518)
The GUI fails to open. This same error can be reproduced by typing "gis.m" at the GRASS prompt. Typing "d.m" at the GRASS prompt does successfully open the GIS Manager.
-------------------------------------------- Managed by Request Tracker
