[GRASS-dev] Adios!
Luigi Pirelli
l.pirelli at acsys.it
Wed May 24 06:05:16 EDT 2006
Hasta Luego...
Thanks really a lot,
ginetto
Radim Blazek wrote:
> Hi.
> I am leaving GRASS project and I have summarized my ideas on vector
> library and modules in GRASS in this document:
> http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/doc/vector/TODO?rev=HEAD&content-type=text/plain
> I'll continue to work on QGIS and GRASS plugin in QGIS.
> I won't be able to work in GRASS PSC but I'll follow the process of
> PSC constitution and I'll do everything I can to ensure that PSC and
> decision making procedures will be democratic and it will take into
> account everybody who is working on GRASS (I mean vote for all
> contributors and clear majority).
> Adios!
> Radim
ATTENZIONE: le informazioni contenute in questo messaggio sono da considerarsi confidenziali ed il loro utilizzo e' riservato unicamente al destinatario sopra indicato. Chi dovesse ricevere questo messaggio per errore e' tenuto ad informare il mittente ed a rimuoverlo definitivamente da ogni supporto elettronico o cartaceo.
WARNING: This message contains confidential and/or proprietary information which may be subject to privilege or immunity and which is intended for use of its addressee only. Should you receive this message in error, you are kindly requested to inform the sender and to definitively remove it from any paper or electronic format.
