[GRASS-dev] [bug #4498] (grass) d.out.png script copied to
docs/html/ in err
Wolf Bergenheim
wolf+grass at bergenheim.net
Wed May 24 11:00:43 EDT 2006
On Wed, 24 May 2006, Markus Neteler wrote:
> How to get
> -for file in *.png *.jpg ; do \
> head -1 $$file | grep '#!/bin/sh' > /dev/null \
> if [ $$? -ne 0 ] ; then
> $(INSTALL_DATA) $$file $(GISBASE)/docs/html \
> fi \
> done 2> /dev/null ; true
> working (in include/Make/Html.make)?
> The problem is that $$? isn't found. Maybe there is a less ugly trick to
> test if
> the first file of the $$file is a shell script.
I'm no expert but shouldn't
if [ ! -x $$file ] ; then \
fi \
do the trick since shellscript should be executable?
--W
<:3 )---- Wolf Bergenheim ----( 8:>
