[GRASS-dev] PROPOSAL: v.edit WAS: d.* commands
Wolf Bergenheim
wolf+grass at bergenheim.net
Thu May 25 03:02:36 EDT 2006
On Thu, 25 May 2006, Jachym Cepicky wrote:
>> If reading from a file then the syntax can be more complex (even XML if we
>> want it to).
> This sounds great! I would suggest, that v.edit should be able to work
> with both - command line arguments for easy editing, file (stdin) for
> more complex ones.
> I also thing, that XML is the way, GRASS should follow.
OK, it will do both. if the file argument is given it will read an xml
document which will contain the actions to take. Do we have an XML parser in
GRASS? I think however that I'll add this file parameter later.
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
