[GRASS-dev] [bug #4493] (grass) gis.m fails to start GUI
Glynn Clements
glynn at gclements.plus.com
Thu May 25 05:38:52 EDT 2006
Michael Barton wrote:
> But this works fine in 8.4 in both x11 and Mac OSX versions on my Mac and
> for FC4. Is 8.4 for Debian so different?
It appears that threading is an optional feature in 8.4.
The Gentoo ebuild for Tcl has a "threads" option, corresponding to the
--enable-threads configure switch. However, it also has this:
pkg_setup() {
if use threads ; then
ewarn ""
ewarn "PLEASE NOTE: You are compiling ${P} with"
ewarn "threading enabled."
ewarn "Threading is not supported by all applications"
ewarn "that compile against tcl. You use threading at"
ewarn "your own discretion."
ewarn ""
epause 5
fi
My guess is that the Debian package uses threads while the FC4 version
doesn't. FWIW, my version was built without thread support.
