[GRASS-dev] [bug #4507] (grass) Error in Grass Installation
Request Tracker grass-bugs at intevation.de
Thu May 25 07:15:20 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4507
Subject: Error in Grass Installation
grass obtained from: Other (CDROM etc)
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.1.cvs_src_snapshot_2006_05_20
   Hemant Here,
   WHile when i Install Grass-6.1 i occurs following error :-
   ./configure --prefix=/usr/local/grass6 --with-postgres-includes=/usr/local/pgsql/include/ --with-postgres-libs=/usr/local/pgsql/lib  --with-fftw-includes=/usr/local/fftw/include/ --with-fftw-libs=/usr/local/fftw/lib/
   make
Errors in:
/root/Desktop/grass-6.1.cvs_src_snapshot_2006_05_20/raster/r.in.gdal
then i have done as follows :-
cd /root/Desktop/grass-6.1.cvs_src_snapshot_2006_05_20/raster/r.in.gdal
make
Then i get following error :-
main.c: In function `main':
main.c:163: error: `GDAL_DCAP_CREATE' undeclared (first use in this function)
main.c:163: error: (Each undeclared identifier is reported only once
main.c:163: error: for each function it appears in.)
main.c:163: error: too many arguments to function `GDALGetMetadataItem'
main.c:165: error: `GDAL_DCAP_CREATECOPY' undeclared (first use in this function)
main.c:165: error: too many arguments to function `GDALGetMetadataItem'
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
Please Reslove
-------------------------------------------- Managed by Request Tracker
