[GRASS-dev] [bug #4509] (grass) Grass Installation
Request Tracker grass-bugs at intevation.de
Fri May 26 00:19:08 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4509
Subject: Grass Installation
Platform: other
grass obtained from: Other (CDROM etc)
grass binary for platform: Compiled from Sources
GRASS Version: grass-6.1.cvs_src_snapshot_2006_05_20
   Thanks for reply.
   as per u r replu i tried but same problem occurs when I try to "Make" the file after "Configure"
    I got following problrm.PLz resolve it on priority.
   I configure Grass as follows :-
   ./configure --prefix=/usr/local/grass6
--with-postgres-includes=/usr/local/pgsql/include/
--with-postgres-libs=/usr/local/pgsql/lib--with-fftw-includes=/usr/local/fftw/include/
--with-fftw-libs=/usr/local/fftw/lib/
   make
After "make" following error occur :-
Errors in:
/root/Desktop/grass-6.1.cvs_src_snapshot_2006_05_20/raster/r.in.gdal
Then i do,
cd
/root/Desktop/grass6.1.cvs_src_snapshot_2006_06_20/raster/r.in.gdal
make
Then following error occurs:-
main.c: In function `main':
main.c:163: error: `GDAL_DCAP_CREATE' undeclared
(first use in this function)
main.c:163: error: (Each undeclared identifier is
reported only once
main.c:163: error: for each function it appears in.)
main.c:163: error: too many arguments to function
`GDALGetMetadataItem'
main.c:165: error: `GDAL_DCAP_CREATECOPY' undeclared
main.c:165: error: too many arguments to function
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
Even i try for Grass6.0 same error occurs
Plz Resolve it on high priroty
-------------------------------------------- Managed by Request Tracker
