[GRASS-dev] Memory freeing errors in NVIZ [bug #4246]
Hamish
hamish_nospam at yahoo.com
Fri May 26 05:24:01 EDT 2006
> If there isn't anything else important in 4246, go ahead and close it
> if this fixed it for you.
> I checked and fixed frees related to every occurrence of Tcl_SplitList
> since its easy to find. It's also used to set the second argument of
> Ngetargs, so I followed it as well (it never gets freed).
> This command run in the nviz directory generates a huge list of other
> things that could be checked:
> fgrep -n Tcl_ *.c | fgrep -v Tcl_Interp | fgrep -v Tcl_Get | \
> fgrep -v Tcl_Free | fgrep -v Tcl_SetResult | fgrep -v \
> Tcl_CreateCommand | fgrep -v Tcl_SplitList
The only reason to keep the bug open is if that fgrep list has
many probables, not just possibles. The bug can be renamed....
Hamish
