[GRASS-dev] nviz colored vectors
Radek Bartoň blackhex at post.cz
Tue May 30 09:56:16 EDT 2006
> Hamish wrote:
> > > Here is colored vector patch for nviz. It uses grassrgb attribute to
> > > get line colors. Displaying of line vectors should work, area vectors
> > > aren't implemented.
> > Hi Radek,
> > thanks for the patch, can you please re-send it as a "unidiff"?
> > cvs diff -u grass6/lib/ogsf/
> Better still, add "diff -u" to your ~/.cvsrc file.
> Nobody uses diff's default output format; most people use either the
> context (-c) or unified (-u) formats.
OK, here is new diff.
الظفر بالضعيف هزيمة
Index: include/gstypes.h
RCS file: /home/grass/grassrepository/grass6/include/gstypes.h,v
retrieving revision 1.1
diff -u -r1.1 gstypes.h
--- include/gstypes.h	5 May 2006 23:28:59 -0000	1.1
+++ include/gstypes.h	30 May 2006 13:53:02 -0000
@@ -159,6 +159,7 @@
     int type;
     float norm[3];
     int dims, npts;
+    int color;
     Point3 *p3;
     Point2 *p2;
     struct g_line *next;
@@ -170,7 +171,7 @@
     int drape_surf_id[MAX_SURFS]; /* if you want 'em flat, define the surface */
     int flat_val;
     int n_surfs;
-    int color, width;
+    int color, width; /* Color is deprecated. */
     char filename[NAME_SIZ];
     float x_trans, y_trans, z_trans;
 /* also maybe center & rotate? */
Index: lib/ogsf/Gv3.c
RCS file: /home/grass/grassrepository/grass6/lib/ogsf/Gv3.c,v
retrieving revision 1.9
diff -u -r1.9 Gv3.c
--- lib/ogsf/Gv3.c	9 Feb 2006 03:08:57 -0000	1.9
+++ lib/ogsf/Gv3.c	30 May 2006 13:53:02 -0000
@@ -10,6 +10,9 @@
 #include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
+#include <grass/dbmi.h>
+#include <grass/display.h>
+#include <grass/glocale.h>
 #include <grass/gstypes.h>
@@ -21,15 +24,34 @@
 /* This loads to memory.
 The other alternative may be to load to a tmp file. */
-geoline *Gv_load_vect(char *grassname, int *nlines)
+	geoline *Gv_load_vect(char *grassname, int *nlines)
     struct Map_info map;
     struct line_pnts *points;
+    struct line_cats *cats;
     geoline *top, *gln, *prev;
-    int np, i, n, nareas, nl=0, area, type, is3d;
+    int np, i, n, nareas, ncols, nl=0, area, leftarea, rightarea, line, type,
+      cat, is3d;
     struct Cell_head  wind;
     float vect[2][3];
+    /* Variables for field info. */
+    struct Option *fieldopt;
+    struct cat_list *catlist;
+    struct field_info *fieldinfo;
+    /* Database variables. */
+    dbDriver *driver;
+    dbString *tablestr;
+    dbTable *table;
+    dbColumn *column;
+    dbValue value;
+    /* Color translate variables. */
+    int has_grassrgb;
+    const char * colorstr;
+    int red, green, blue;
     /* TODO: handle error messages */
     Vect_set_open_level (2);
@@ -46,13 +68,50 @@
     #endif
     points = Vect_new_line_struct ();
+    cats = Vect_new_cats_struct();
     G_get_set_window (&wind) ;
     Vect_set_constraint_region(&map,wind.north,wind.south,wind.east,wind.west,
 	                       PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
     is3d = Vect_is_3d ( &map );
+    /* Get field and field info */
+    fieldopt = G_define_standard_option(G_OPT_V_FIELD);
+    catlist = Vect_new_cat_list();
+    catlist->field = atoi(fieldopt->answer);
+    if ((fieldinfo = Vect_get_field(&map, catlist->field)) == NULL)
+      G_fatal_error(_("Database connection not defined"));
+    /* Connect database. */
+    if ((driver = db_start_driver_open_database(fieldinfo->driver,
+      fieldinfo->database)) == NULL)
+      G_fatal_error(_("Can't open driver %s"), fieldinfo->driver);
+    /* Check if grassrgb attribute is present in table. */
+    db_init_string(tablestr);
+    db_set_string(tablestr, fieldinfo->table);
+    if (db_describe_table(driver, tablestr, &table) != DB_OK)
+      G_fatal_error(_("Can't get schema of table %s"), fieldinfo->table);
+    has_grassrgb = 0;
+    ncols = db_get_table_number_of_columns(table);
+    for (n = 0; n < ncols; n++)
+      column = db_get_table_column(table, n);
+      if (!strcmp(db_get_column_name(column), "grassrgb") ||
+        !strcmp(db_get_column_name(column), "GRASSRGB"))
+        has_grassrgb = 1;
+        break;
     /* Read areas */
     n = Vect_get_num_areas (&map);
     nareas = 0;
@@ -125,7 +184,9 @@
     /* Read all lines */
     G_debug(3, "Reading vector lines ...");
-    while (-1 < (type = Vect_read_next_line(&map, points, NULL))) {
+    n = Vect_get_num_lines (&map);
+    for ( line = 1; line <= n; line++ ) {
+        type = Vect_read_line (&map, points, cats, line);
 	G_debug(3, "line type = %d", type);
 	if ( type & ( GV_LINES | GV_FACE ) ) {
@@ -181,7 +242,38 @@
 		GS_v3cross( vect[1], vect[0], gln->norm );
                 G_debug ( 3, "norm %f %f %f", gln->norm[0], gln->norm[1], gln->norm[2] );
+            if (has_grassrgb)
+              /* Get line or area category. */
+              if ((cat = Vect_get_line_cat(&map, line, catlist->field)) < 0)
+                gln->color = 0x00000000;
+                continue;
+              /* Get grassrgb attribute value. */
+              if (db_select_value(driver, fieldinfo->table, fieldinfo->key, cat,
+                "grassrgb", &value) == -1)
+                G_fatal_error (_("Can't get grassrgb attribute value for line %d"),
+                  cat);
+              colorstr = db_get_value_string(&value);
+              if (!colorstr)
+                G_fatal_error (_("Color definition column (%s) not a string. "
+                  "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
+                  "grassrgb");
+              G_str_to_color(colorstr, &red, &green, &blue);
+              gln->color = red | (green << 8) | (blue << 16) | 0xFF000000;
+            else
 	    if (NULL == (gln->next=(geoline *)malloc (sizeof(geoline)))) {
 		fprintf(stderr,"Can't malloc.\n"); /* CLEAN UP */
 		return(NULL);
@@ -206,7 +298,11 @@
     #ifdef TRAK_MEM
     	Tot_mem-=sizeof(geoline);
     #endif
+    if (driver)
+      db_close_database_shutdown_driver(driver);
     Vect_close (&map);
     fprintf(stderr,"Vector file %s loaded.\n",grassname);
Index: lib/ogsf/gvd.c
RCS file: /home/grass/grassrepository/grass6/lib/ogsf/gvd.c,v
retrieving revision 1.6
diff -u -r1.6 gvd.c
--- lib/ogsf/gvd.c	9 Feb 2006 03:08:57 -0000	1.6
+++ lib/ogsf/gvd.c	30 May 2006 13:53:02 -0000
@@ -139,6 +139,12 @@
+        /* Set line color. */
+        if (gln->color != 0x00000000)
+          gsd_color_func(gln->color);
 	if ( gln->type == OGSF_LINE ) { /* line */
 	    if ( gln->dims  == 2 ) {    /* 2d line */
                 G_debug(3, "Draw 2D vector line.");
