[GRASS-dev] [bug #4522] (grass) r.series: error in row of input map is non-fatal giving wrong results
Tue May 30 22:50:48 EDT 2006
> > The read error should trigger a G_fatal_error().
> Agreed. The question is: why does libgis leave this to individual
> modules rather than doing it itself? Are there really modules which
> might want to do something other than call G_fatal_error() in this
> case?
I doubt it.
Is there a possibility of many orphaned .tmp files if the module exits
during a read while an output map open? i.e. how important is it to exit
with clean-up at any given point of a typical raster [read; do stuff;
write] operation?
Hamish
